removing dash bezel around the head unit.
Old May 13, 2005 | 09:46 PM
delusion's Avatar
Default removing dash bezel around the head unit.
hey does this thing pop out? how do i remove it? I need to get to the back of the panel where the ASR and fog light switch is.
Old May 13, 2005 | 09:55 PM
Black8Banger's Avatar
yes just pull on it
Old May 13, 2005 | 11:34 PM
02Z28LS1's Avatar
if you have a little bit of fingernail left, you should be able to get your nails under it at the top-left corner and just pull straight out, and it should just come out. there are 4 tabs holding it on, 2 at the top and 2 at the bottom. you should also be able to get a flat-blade screwdriver behind it if you don't have any fingernails.
Old May 13, 2005 | 11:38 PM
Richiec77's Avatar
Hell. Stick your fingers in the Vents and Tug a little bit. You'll feel it moving. It will then just "Pop" out. Might hear a Little Screatching from the Metal tangs, but that is normal.
A Cracking sound isn't though. Also don't yank too hard. You have Wiring behind the panel that is connected to the Switches.
Good luck. Really simple and you'll be an Expert after 1 time.
Old May 17, 2005 | 02:02 PM
Roarin_8's Avatar
Just pull on it, it will come out. I did this last night when I replaced my tape deck with a CD deck.
