radio noise....please help.
Old May 25, 2005 | 08:42 PM
badtexasZ28's Avatar
Default radio noise....please help.
first off i did use the search function with no results, i have a ticking/popping noise that is coming from my radio while the engine is running, it does not do it with the engine off or with a CD playing. also it is RPM dependent too...what could this possibly be? the radio is the stock monsoon CD player HU and nothing has been done to the system to cause this noise....
Old May 25, 2005 | 09:57 PM
redline2k's Avatar
am or fm? Make sure your antenna is not loose. Also did you change plug wires recently? Could be rf interference from the ignition system if you have worn plug wires that are arcing. Most car audio noises are caused by poor grounding.
