door speaker size
Old May 31, 2005 | 08:13 PM
nirvana91's Avatar
Default door speaker size
my door speakers are blown and i dont want to go pullin off my door panels jus too find out what size to just have to do it again later so i need just a lil help. my speaker code is uz7 which says i have 4 dr speakers, 2 sail panel a 2 rear qtr. i have glanced at the 2 rear and they r like 31/2in. infinity's which i thought was small but anyway what size are the door and sail panel speakers? and for the rears how big can i actually go back rthere. thanks for the help.
Old May 31, 2005 | 09:14 PM
Daley's Avatar
First, the Camaros are different than the Firebirds, and Monsoon/non-Monsoon matters too. Second, and I don't mean to be a dick, but pretty-much everything you'll need to get yourself started has already been talked about - check the stickies at the top of this section or use the search button. Everyone's here to help, but you've gotta do a little homework on your own first.
Old May 31, 2005 | 11:33 PM
Luna's Avatar
Well If you have a firebird I can tell you right now that even though it says it is 6 1/2 " for the doors it is 6 3/4" I just recently replaced mine because they were blown out too the guy at best buy said his computer told him 6 1/2s but I brought the original and a 6 3/4 will drop right in. BTW I do have a monsoon system so if you have it too then you are set. Also if you replace them with anything more than a two way I recommend unplugging the tweeters on the doors because the treble is way overpowering. I put some four ways in and my ears were going to explode till I unplugged the tweeters on the doors. Hope this helped!!
Old Jun 1, 2005 | 01:40 PM
nirvana91's Avatar
i understand the thing on people askin stupid questions like what plugs should i put in or somethin like that but i think my question is legit. i found nothing searching on what size speakers would be there and nothing at the top of the forum. i dont have the monsoon system, its got the factory cassette deck with 12 disc changer, it is a camaro, i only stopped in this forum jus to find out what was in there, no biggie, anyone know? thanks
Old Jun 1, 2005 | 04:18 PM
Luna's Avatar
You're best bet is to just rip the door apart and take out the stockers , take em to wherever you're buying your new speakers and match them up against what they have in stock, thats what I did.
Old Jun 1, 2005 | 04:51 PM
nirvana91's Avatar
sounds like the best way, thanks
Old Jun 2, 2005 | 11:01 AM
WhiteBird00's Avatar
Ungrounded Moderator
The speaker sizes are the same for the 10-speaker (8-speaker in Camaro) "premium" audio system as they are for the Monsoon system - they mount in exactly the same places. The difference is in the design of the speakers themselves. Monsoon systems use 2-ohms for the speakers that are connected to the amp (basically all except the tweeters).
So, the doors and sail panels use "oversize" 6.5 inch speakers (6.75 inch fits well) and the hatch area has 4 inch speakers.
Old Jun 2, 2005 | 04:18 PM
nirvana91's Avatar
thank you guys alot i appreciate it
