Cd changer problem
Old Jun 19, 2005 | 10:43 PM
01sunsetSS's Avatar
Default Cd changer problem
Hey all, recently my 12 disc changer randomly stopped working. I load up all the discs in the changer and close it and i can hear it start to read the cds then the headunit just says error. The cds wont play at all no matter how many times i try to load them. Any ideas?
Old Jun 20, 2005 | 06:54 AM
WhiteBird00's Avatar
Ungrounded Moderator
This may sound foolish but it's always best to check the simple things first - you are loading the discs upside-down, right? The factory changer is the only one I've ever seen that loads the discs with the label side down.
Other than that, it sounds like the changer itself is on its way out unless you would have some reason to suspect that the cable has come loose (installed other accessories where the cable might have been disturbed).
Old Jun 20, 2005 | 09:08 AM
01sunsetSS's Avatar
Hahaha yea been using the cd changer for over two years, im definitely loading them correctly. I dunno the things done nothing but **** me off anyway ill probly just trash it.
Old Jun 20, 2005 | 10:12 AM
shouldaboughttheZ's Avatar
does it give you an error code?
Old Jun 20, 2005 | 10:27 AM
Addicted's Avatar
One thing I've aways had a problem with is if i'm using burned CD's that are of cheap quality my changer won't read them. You might make sure you have one good store bought CD in there and see if that works.
Old Jun 21, 2005 | 12:27 AM
01TAFlyer's Avatar
Originally Posted by 01sunsetSS
Hahaha yea been using the cd changer for over two years.
I think it is done as well. Could be that something has come off balance or out of alignment, such as the laser or lens. May not be worth the money to try and get it fixed if it is broken. I bought myself one on a board for $150 with an extra magazine. They come up pretty often.
Old Jun 21, 2005 | 12:40 AM
01sunsetSS's Avatar
Yea i think its probly best to just get rid of it. Its always been a pain in the *** to load, took two or three tries to get it to read all the discs without giving an error before. So now that it isnt reading them at all, **** IT IM DONE
