Comments and questions - I shopped today
Subs: I was told by several different people (installers) that the W6 will be more efficient and hit better and be more clear than the W7 in the C5 Coupe because of the amount of travel the W7 requires. Exact words, the quality of sound the W6 will be better than the W7. So, if I go the W6 route, should I run a 12W6? Anyone have comments?
Rear channel: Are most here satisfied with just a front stage setup? Or should I put some components in the rear as well like a lower model Focal?
Amps: I will be running a JL 500.1 on the woofer. If I have front and rear channel components should I run 3 amps? Or would a 450.4 do the trick? If I only run the front components, which amp would you recommend?
Thanks!
I'm baffled pretty bad here.
, but i hate bostons
. Everyone has thier own tastes.And if your looking at that bok a w6 will be great. No reason to cram a w7 in there unless you just want to say "Oh yeah, I have a W7 in my car
" Trending Topics
Have you tried listening to any MB Quarts.
Either way the focals are the better way to go. Might have been something wrong with their display.
