How much power does the stock amp have?
On a side not is the power from the stock monsoon amp running to the door speakers at 2 ohms or 4 ohms? Because i set it up as if the speakers I replaced those with were just getting there power from the amplifier and I dont want to blow my new speakers.
Thanks for any help.
hmm good idea As for powering a 10" with a monsoon. I think that would work horribly. There are a list of reasons this won't work well. The sail panel speakers don't have tweeters which is why they weren't being sent high frequency.
The monsoon doesn't have enough power to blow anything unless you run in clipping and I'm not sure it will even do that. I'm not sure what "system" you installed... sounds like some door speakers. Anyway, some people run stock monsoon and speakers and add an amp and a sub. Many will just chuck the entire monsoon system and install a quality amp(s), door speakers and sub.
Brian
Thanks again for the help...
