Using new wire, or use existing wire?
Do you tap into existing wires that already run through the car? Do you run totally new wires? Does the adapter plug that plugs into the stock amp have wires that I can tap into that are in the door?
Your help is superly appreciated!! Thanks.
I already had the car torn apart to install rca's and power wire. Installing the 12 gauge was not much trouble.
The stock wiring is likely to be 18 gauge or more. If your door speakers are not more than ~50 watts rms, I'd say go ahead and reuse the factory wiring. You'll have to cut and splice into the factory amp connector - or make/get terminals that fit into it (32 pin blue connector by the amp).
Look at post #4 in this thread http://web.camaross.com/forums/showthread.php?p=3199862 for the a link to the wiring diagrams.
GPz: Do you like your setup or would have done anything different. Just looking at you sig and saw all the alpines. I have an alpine hu, but I had heard a lot of mixed reviews on their component sets. Just looking for your opinion.
Hopefully everything will hold up and sound as good in the future as it does now.
I may have to look it for a little better setup on my car now.
