Help with alarm
Old Jul 26, 2005 | 12:19 AM
quiksilver9531's Avatar
Default Help with alarm
I got a viper 690xv responder installed in my '00 transam and I was wondering how you adjust the sensitivity on them, I found a shock sensor and the main cpu thing for the alarm but I dont see anything thats for adjustments, i just see a bunch of wire harnesses plugged into the cpu, no sensitivity screw or anything, any help is appreciated thanks
Old Jul 26, 2005 | 09:56 PM
anybody?!?!
Old Jul 26, 2005 | 10:11 PM
02NBMSLPSS's Avatar
Default re alarm
if it is a newer model, the shock sensor will be a little clear box with an orange adj screw on the side.
Old Jul 27, 2005 | 07:54 PM
oh really so the senstivity isnt on the main box its on the shock sensor, thanks man
Old Jul 27, 2005 | 11:39 PM
02NBMSLPSS's Avatar
Some older alarms had onboard shock sensors and some code alarms still do. Most newer dei alarms (viper, python, hornet, etc.) have outboard, little clear box, probably 2in by 2in., the adj screw on side kind of hard to see, uses a phillips head or you could probably fit a tiny flat head to make adj. Let me know if you need anymore help.
