96 in a 99??
Old Jul 31, 2005 | 03:21 PM
FormulaFire's Avatar
Default 96 in a 99??
will a stock 96 radio work in a 99 TA?
Old Aug 2, 2005 | 04:55 PM
WhiteBird00's Avatar
Ungrounded Moderator
Yes, as long as the 96 radio isn't a Bose model.
Old Aug 3, 2005 | 08:13 AM
I hooked it up, and I could get it to light up. The clock would work, but I couldn't get any stations to come up or music to play..
Old Aug 3, 2005 | 08:26 AM
If you took a 96 T/A radio (that wasn't Bose) and installed it in a 99 then it should work fine. If it doesn't then there is something wrong.
Possible problems: the 96 radio is no good; you are replacing an aftermarket radio in the 99 with a factory radio from the 96 and the wiring in the 99 has been modified for the aftermarket radio; or, it could be something as simple as a blown fuse. There are two fuses for the radio in the 99 - one for the clock and station memory and the other to actually power the radio. Check the 15A fuse labeled RADIO and see if that is the problem.
