Aftermarket speakers
Old Aug 13, 2005 | 06:37 PM
z28C4maro82z's Avatar
Default Aftermarket speakers
I put pioneer 3 way speakers in my front door.....When i turn the volume up with them on....I get a crackling....Is this the wiring or the monsoon amp???? What's the problem
Old Aug 13, 2005 | 08:27 PM
shouldaboughttheZ's Avatar
It is probably the speaker. There are 4 wires that go to the front door speakers. 2 got to the tweeters from the radio, and the other 2 got to the 6.5" from the amp. Make sure you are using the correct set of wires, also make sure the connections are good.
Old Aug 13, 2005 | 10:49 PM
sercastiK's Avatar
run the wires on the left side of the plug itll work fine....just run 2 wires not 4.
J
Old Aug 14, 2005 | 09:03 AM
iosigma's Avatar
Also make sure you tape up the wire your not using. Also remeber that the monsoon amp puts out a different ohm load and also builds in some distortion. Your speakers may be under powered. Just a thought
Old Aug 14, 2005 | 12:23 PM
The underpowering of the speakers was what a few people said......The speakers are 220 watt a piece.....So I'm guessing I need to amp them
Old Aug 14, 2005 | 12:57 PM
prelude00782's Avatar
yes sounds like they might already be blown though. Make sure you stay within the RMS range between the speakers and amp.
