Need help with power antenna
Old Aug 14, 2005 | 03:56 PM
Sticks1130's Avatar
Default Need help with power antenna
The other day my antenna stopped working and is stuck up. I can hear the motor working but the antenna doesnt move and there isnt a loud grinding noise or anything like that. I searched all i found was to try cleaning it or just replace it. Ive tried cleaning it and got no results so i was just wondering if there are any other things i should try before i just replace it.
Old Aug 15, 2005 | 02:47 AM
CrawlinWS6's Avatar
Import Patrol
the ant. itself is has a gear on it. If you look the ant. has a long piece on plastic on it with teeth. that section runs through the gear in the motor, check to see that it was not thrown off at all.
