Wiring question for the electro-guys Here is what I need to do… I want to have a switch that creates a circuit. In this circuit I also want to have a push button that will break the circuit even though the main switch is still on. Then when I flip the main switch off and back on I want to re-establish the circuit. Any ideas on the cleanest way to do this? Also, anyone know what wire is switched power on an 02 camaro? |
sounds like a circuit breaker to me bu,t I'm sure you don't want a household circuit breaker in your car, do you? |
Yoda - you seek Yoda! I think all you'd need is a couple of relays and some time. there are several 12vdc power wires on your car. Hayne's manuals have some decent schematics that should help you. |
Sounds like he wants a self resetting latch of some sort. What's the rest of the circuit look like. What are you trying to control. |
Well here is what I’m trying to do. I’m looking for a better way to control my line lock so I can do controlled burnouts at the track and then toll out of it without having to flip a switch. I’d like to press the brakes and then flip an ignited protector switch to enable the lock. Once I’m done roastin em up I want to just hit a button that will release the line lock noid. Now the catch is that in this situation I would want the line lock noid to engage the very next time I flip the main ignited switch on. Make sense? |
How about eliminating the toggle switch and just using a push button with a latching relay to perform both on and off functions? Or, for that matter, what about just getting a push on/push off switch? |
© 2024 MH Sub I, LLC dba Internet Brands
