Can you help me figure this out?
, but my question is that im using each of the 4ch's to power my pioneer speakers, and the other CH. to power ONE of my subs, but can i bridge both of my subs to run on the same 5th CH.?. Im almost certian that it would be ok, and i wouldent mess with running the incorrect ohms, but i want to make sure....the subs are the 12W3v2-D4 JL audio, 4 ohms.
here is a link to the alpine pfd amp specks....
I am running the 5ch setup @ the end of page 13, not @ the top.
http://www.stylestandard.net/oswego/....entity.Entity[OID[EA1657426FF4A34780EA61C1E60FC12C]]
Thanks guys
edit: http://www.lalena.com/audio/faq/wiring/
EDIT: For two 4 ohm speakers, the total impedance would be 2 ohms. This is correct right, now i just have to make sure the amp can take the 2ohm load?
mm like this?
AMP LINK
http://www.stylestandard.net/oswego/...E60FC12C%5D%5D
another thing you could try is running the subs in series, even though the faq i linked says its not recommened i have done it before without problems.
