2 lights down?
Old Oct 11, 2005 | 09:37 AM
99midnightZ's Avatar
Default 2 lights down?
i posted a long time ago about my blinker lights not working. i found the light that i needed to change and changed it. my blinker has worked for about 2 weeks and then it blew...i changed it again and once again it blew after a week or 2. im getting the right bulb and i have tried all different brands and types. anyone have any clue what's going on? any help would be nice
Old Oct 11, 2005 | 09:46 AM
John -- '02 HAWK's Avatar
could be a bad socket elsewhere I had to replace both of my front sockets
Old Oct 11, 2005 | 05:58 PM
hmm..anyone else have any other ideas
Old Oct 12, 2005 | 07:08 AM
WhiteBird00's Avatar
Ungrounded Moderator
Our cars are notorious for getting water in the front turn signal housings causing corrosion. Also, water inside the housing splashing on a hot bulb will cause it to burn out. Check if the housings are corroded and replace them if they are. If they're still OK then adding some weather sealer around all the seams might help.
