help please
Old Oct 15, 2005 | 12:12 AM
volcanic2345's Avatar
Exclamation help please
ok i changed my headunit and now i have a weard sound like a screaming noise i checked all my grounds but still here the noise when i turn the amp up it get worse what can i do
Old Oct 15, 2005 | 12:20 AM
GPz1100's Avatar
Considering using proper punctuation in your post. Such things as periods, commas and capital letters really do make reading your run-on sentence easier.
With that aside, it sounds like you didn't use the correct wire for your remote lead. After the head unit is turned off, the output of the amp is not cutoff right away. What you're hearing is the amp bleeding off any stored energy.
Generally, the remote turn on input of an amp not only turns the amp & output stage(s) on, but conversely turns the output stage(s) off right away when the HU is powered down.
Old Oct 15, 2005 | 12:33 AM
i know i was in a rush , iam trying to get this fixed what do i need to do? thanks and would a filter do anything i have an audiobahn amp for my 2 12s (also audiobahn) and a kicker amp for my highs (4 speakers (inside)2 are kicker and 2 are infinty),and a crossover plus an epicenter
