MTX 2150x and subs question.
So now I need new subs, with the MTX it is about 500 watts into a 4ohm mono load or 250 watts x 2 into a 2 ohm load. Does that mean in stereo I can do a 2 ohm and mono a 4? Or should I go with a 8 and 4 ohm sub like before to get that extra power out of the subs in a 2.66 ohm load and have the best of both worlds, not a 2 ohm load to heat up the amp and fry it. Has worked the last couple years perfect. Then the question is what subs now? for 5 years I've run the JL's and car audio changed so quick. What would be a good sub in a millhouse box for this amp? Thanks in advance.
Yes that is correct because once the channels on the amp are bridged it will read as half the resistance. (in other words both will read a 2 ohm load at the amp level)
