Security Light
Old Nov 28, 2005 | 01:14 PM
JohnnySuperSport's Avatar
Default Security Light
So my security light is always on when the key is turned, anyone know what this might be?
Old Nov 29, 2005 | 12:33 PM
bump.T
Old Nov 29, 2005 | 07:49 PM
WhiteBird00's Avatar
Ungrounded Moderator
The most common cause is dirt on the chip contacts in the key or on the contacts inside the ignition cylinder. Clean the key with a pencil eraser, rubbing alcohol, or spray contact cleaner. If that doesn't solve the problem then use the spray contact cleaner in the ignition cylinder.
