monsoon wiring #2
Old Dec 1, 2005 | 09:14 PM
LC's Avatar
LC
Default monsoon wiring #2
Well since server freaked out on the first try...
Does anyone have a diagram of how is all the monsoon system wired?
I already pulled the harness to the front passenger side, but i can't get pass it.
Looks like i will have to remove the dash to do so. Some of what look to be nothing related to audio, more like BCM/PCM connectors go throught the audio harness wtf!
Old Dec 1, 2005 | 10:29 PM
DAVESS02's Avatar
http://www.houston-f-body.org/tech/monsoon/
I used this site to wire my 02 camaro. I used the stock H/U and purchased
an eclipse amp that uses high level inputs and matched them up with front
and rear components also from eclipse. I'd be glad to help you if you have any questions.
Old Dec 1, 2005 | 11:09 PM
LC's Avatar
LC
Thanks Dave.. i saw that on my search around, but i'm trying to remove all the wiring to elimate weight... (sure that harness doesn't weight a lot but if there is no use to it, i just find it bulky around)
Removed the Deck, rear speakers, amp, antenna..
Still gotta remove the front speakers...
