Turn Bulb
Old Dec 7, 2005 | 05:47 PM
Super Speed's Avatar
Default Turn Bulb
I bought the replacement bulbs but I don't know how to get to them...Is there a writeup? Or does anyone here know how? Thanks!
Btw I tried search already!
Old Dec 7, 2005 | 07:06 PM
evilbadz's Avatar
Well I've changed them many times, it is possible to change it without taking off anything but easier and less time to take off the headlight generally.
What I do is unplug the 2 bulbs from the headlight, then remove the 2(i think) bolts holding the assembly in. After that it's tricky bending/prising to get the headlight assembly out.
After it's out, they are a snap to change and take like 20 seconds to be done with, then just reinsert the headlights, bolt back together, put in the bulbs, and shut the hood
Hope that helps some
Old Dec 7, 2005 | 08:50 PM
GETGONE's Avatar
That's the HARD way to do it. Underneath the front corners there are flaps on each side. I believe there are 2 7mm bolts holding the edge in. Undo those and you can drop the flap down and reach up inside and get to the bulbs.
Old Dec 7, 2005 | 10:39 PM
ABeasst's Avatar
they're actually 10mm bolts but yea what he said.
Old Dec 8, 2005 | 07:06 AM
Thanks! My dad changed em for me took him about 20 secs! I guess my blinker problems weren't a bulb now I gotta change a relay
Old Dec 8, 2005 | 08:03 AM
WhiteBird00's Avatar
Ungrounded Moderator
There is no relay for the turn signals. It also isn't the flasher causing the problem unless both sides aren't working. A single flasher runs both sides so if one side works but the other doesn't then it can't be the flasher causing the problem.
If it's just the front signal on one side that isn't working and you've replaced the bulb then check that the bulb socket isn't corroded. That's a fairly common problem.
Old Dec 13, 2005 | 02:38 PM
The idiot guy at orielys gave me a drl bulb instead of a turn signal bulb it was small. I went to the zone and they gave me the right one, to bad i'd already replaced the flashed Meh it sounds nice though so its alright hehe...
