pre amp voltage
Old Dec 8, 2005 | 07:11 PM
1hot91's Avatar
Default pre amp voltage
i need a suggestion on what to use to up the preamp voltage on my head unit?
Old Dec 9, 2005 | 08:04 AM
HiTechGent's Avatar
Why? What do expect that to do for you?
Old Dec 9, 2005 | 06:44 PM
1hot91's Avatar
why ask why to a question? i am looking for suggestions because i'm looking into purchasing a preamp voltage booster because the preout voltage is lower then i'd like it to be. the advertised 5volts is more around 2 volts and i'd like to get it closer to 8 if possible.
if anyone has a suggestion on a brand of preamp booster then let me know or something similar. thanks.
Old Dec 14, 2005 | 01:20 PM
marcus769's Avatar
LOL! I dont know of anything. Most i've seen is like 4.5-5.0 Volts. I'm sure you can be done... Good luck!
Old Dec 14, 2005 | 01:33 PM
KevinWS6's Avatar
What you need is called a line driver. Alot of companies make them, just get it from a reputable company and you will be fine. This would be my suggestion:
http://www.mobileaudiocontrol.com/de...d=5249&l1=5249
The overdrive and the matrix are both good choices.
Old Dec 14, 2005 | 02:00 PM
thaar's Avatar
PG makes a good one (TLD66)to boost voltage to 8. This Cadence is also a great line driver http://www.woofersetc.com/index.cfm?...roduct_ID=1278
Do you really think you need one though?
Old Dec 15, 2005 | 08:15 AM
1hot91's Avatar
thanks for the suggestions, i appreciate it and no i don't think i need one.
