Help me pick out speakers
I plan on getting the speakers first, and keeping it that way for a while. But I do want to run amps and possibly a 3 10 subthump box. So want to help me out with that selection too? I think I will need 3 amps, since I have three rca's on the back of the head unit, front, rear, and bass.
Moneys a object, but if it comes down to it, I wouldnt mind spending money if I cant possibly get something decent for less.
Thanks in advance.
Option 1: Replace the front speaker with 2 or 3 way 6 1/2 and the Sail speakers with a 2 way and run it off the head unit. This is by far the cheapest way sound quilty "might" be better than what you have now. If you run the 3 10's with this set up the bass will drown it out, which will make you tune tune the bass so you can hear the words.
Option 2: Put a set of componets up front and a decent 2 way in the rear and amp them. you can use a 4 channel amp or save alittle money and get a 2 channel amp. This will sound 100Xs better that what you have but will also cost twice as much as the first option.
