another alarm install
Old Dec 21, 2005 | 12:14 PM
jimmy 2 Times's Avatar
Default another alarm install
so i am going to be putting another alarm in my car. My last one, was just a cheap and easy install. Now that i have installed more alarms in cars, i figured it was time to re-do mine.
I am looking for a few suggestions:
first, where did you guys mount you blinking alarm light? I was thinking in the factory location, but i dont see how to get that damn thing out? Any help, or other recomondations?
2, where did you put your alarm brains? I want it out of the way, so it can not be easily unplugged. How about under the pass airbag? or perhaps behind the guage cluster?
3, did you guys use 2 relays for the locks, or did you use the DEI 451m that comes with the 791?
That is it for now........i think
Old Dec 21, 2005 | 06:13 PM
01 Red WS6's Avatar
on my truck the brain of the alarm is mounted behind the kick panel on the driver side. It fit perfect too.
Old Dec 22, 2005 | 08:52 AM
that is usually the first place a theif will look, and is not what i am after
Old Dec 22, 2005 | 09:49 AM
01 Red WS6's Avatar
ok well pull the top off the dash and put it in there. There should be enough room up there... running the wires might be a little tough but it could be done
Old Dec 22, 2005 | 01:11 PM
BlkTARebel99's Avatar
put it behind the light switch.
Old Dec 22, 2005 | 01:25 PM
thaar's Avatar
In my old car, I put the brain in the drivers side door panel.
