Installed some new toys
The only thing that I find strange is the front speakers now are not as loud as they were before. They sound clear, but I have to fade the head unit foward to balance things out. It was the opposite before with the stock monsoon. Any one have any ideas what could be causing this?
Oh yeah the car is a '01 formula. Thanks.
IF so, did you hook both tweeter and woofer thru the crossover module? If you did, that would explain why you don't get the volume from the front channel you should be. As you would have to have used the tweeter input (from the head unit) rather than the amplified woofer input for it to sound right.
If this is the case, all you need to do is disconnect your woofers from the crossover and hook them up to the old woofer input wires. The Monsoon amplifier has built-in crossovers, so no worries about that.
The new speakers are all 2 ohm, so I figured it was something else. I have the crossovers that came with the new speakers, but did not install them yet. I have a 4 channel amp I am going to install once it gets warmer, and was going to use them then. Also waiting to install my stealth box and 2 channel amp. (it's mighty cold in jersey as of late.)
I appreciate any help, Thanks
