blowing fuses, help
the amp on the right is a PG xenon 400.1, i think...i can never remember the exact name. anyway it calls for a 40 amp fuse. i have 4 gauge wire fused running from the battery back to a dist. block. and tywo 8 gauge wires, pne to each amp. the dist. block also has fuses, one for each amp, that is the fuse that keeps blowing. i'm on my third fuse now, first it blew a 40 amp fuse, i could only find 60 amp replacement fuses, a week or two later that fuse blew. now i'm on another fuse and the amp has randomly turned off while the system was operating atleast twice. i figure maybe the amp is getting hot, but it has a built in fan and is never as warm as the other amp.
the main wire has a 100 amp fuse, and originally, the dist. block had a 60 and a 40 amp fuse. now it has two 60 amp fuses which i didnt think would hurt be cause they are already fused at the batt.
whats my problem?
Beyond that I would make sure you aren't improperly loading the amp. For example showing it a 2 ohm load when it is only rated for a 4 ohm load. Many amps that are rated for 2 ohms are not 2 ohm capable when bridged.
If all your wiring checks out - maybe try changing the load from 2 to 4 ohms and see if it still shuts down.
From what you are describing I suspect it is a case of improper loading.
i think what i'm going to do is rewire the subs for a 4 ohm load and see if that helps for now.
