Antenna ?
Old Dec 26, 2005 | 09:09 PM
4mula4ever's Avatar
Default Antenna ?
My antenna on my 95 formula doesnt work anymore and I hate it just sticking up in the air. I don't use radio anyways so is there a way to get it to go down and stay down because it wont just gto down if I try to push it down.....
thanks
Old Dec 27, 2005 | 09:36 AM
VIP1's Avatar
Copy & Paste Moderator
Is it stuck up?
If it is, I dont know the best way to get it down.
If not, then you can put a switch in-line with the antenna's power wire. The antenna requires constant power to stay up. If you cut the power to it, it will go down.
Old Dec 28, 2005 | 01:04 AM
2002_Z28_Six_Speed's Avatar
Take it apart and then remove the plastic wire that makes the antenna retract. It is like a plastic ribbon with teeth on it that goes all the way through the antenna. It would colaspe then. Put it back together afterwards. They have a factory repair kit for the plastic teeth. Or maybe the motor is stuck. Maybe you could just buy a used one.
