MTX amp, Kicker sub, Pioneer headunit....
-Philip
MTX Thunder421D
210 watts x 1 at 4 ohms (at 14.4 volts)
» 420 watts x 1 at 2 ohms (at 14.4 volts)
» requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
» Adaptive Class D Technology
» variable 40-200 Hz low-pass crossover, 24 dB/octave
» preamp outputs
» PWM MOSFET switching power supply
» gain control
» Thunder EQ bass boost (0-18 dB at 40 Hz)
» speaker-level inputs with SmartEngage (turns on the amp when it detects signal from the receiver, eliminating the need for a turn-on lead)
Kicker CompVR 05CVR104
10" sub with dual 4-ohm voice coils
» suitable for marine use
» injection-molded polymineral cone
» double-stitched, foam-ribbed Santoprene rubber surround
» frequency response: 25-500 Hz
» power handling: 50-300 watts RMS
» peak power: 600 watts
» sensitivity: 85.5 dB
-or-
10" subKicker Solo-Baric L5 05S10L54
woofer with dual 4-ohm voice coils
» SoloKon aluminum-treated composite cone with Santoprene rubber surround
» frequency response: 24-100 Hz
» power range: 50-450 watts RMS (225 watts per coil)
» peak power handling: 900 watts
» sensitivity: 86.5 dB
» top-mount depth: 6-3/16"
» sealed box volume 0.66-1.0 cubic feet
