Electronics-dome light flashes with key in ignition
Old Feb 5, 2006 | 08:12 AM
8a8mfh's Avatar
Default Electronics-dome light flashes with key in ignition
I have a problem with my dome/mirror lights. Normal operation would be to shut the key off and stay in the car, the lights would fade out. Now they start to fade out and pop back on, start to fade out and pop back on. All this without touching anything.
Also the door chime or whatever it's called sometimes does not work with the door open and key in the ignition, then all of a sudden it will start to work. Sometimes it sounds normal, sometimes it goes real slow and cuts on and off.
This is in a 2002 camaro. Any idea what the problem could be?
The battery is good.
