Fuse Question
Old Feb 7, 2006 | 02:35 PM
chameleont/a's Avatar
Default Fuse Question
Just had a quick question about my sum/amp set up. I have 2 12's and a relatively small amp trying to push the subs. Every time i turn the bass up my amp fuses blow. They are two 30A fuses. I realize to not get them to blow i have to turn down the bass, but what would happen if i just replaced the fuses with 40A fuses. I plan on getting a new amp anyways, so if the worse case scenario is i just burn up the amp then so long. I just dont want to catch anything on fire. Thanks for the input.
Old Feb 7, 2006 | 07:46 PM
Blacker's Avatar
Most likely, you are overdriving the amp. If you replace the 30A with 40A, you may cause internal damage. I would make sure the amp was supposed to have 30A fuses. I was blowing a 50A fuse on my PPI A600, many years ago, and it was caused by overdrive the amp into a 2 ohm load brigded and the amp was only 4 ohm stable.
