Power Wire Routing/Ground
Old Feb 17, 2006 | 09:14 AM
HowellSoccer88's Avatar
Default Power Wire Routing/Ground
Whats the best way to run the power wire for an amp from the battery to the rear hatch area and whats the most stable ground in that area? Sorry if this is a repeat and I am new to car audio so just looking for a little help! Thanks a lot!
Old Feb 17, 2006 | 02:54 PM
ded71's Avatar
There is a hole in the fire wall on the passenger side. You have to move the comp. out of the way. It is down low, it comes out behind the kick panel on the passenger side of the car. The hole is big, just have to poke a hole in the grommet. I ran 4 gauge through there with plenty of extra room. I used a bolt back by the hatch lock mechanism for my ground and so far so good. good luck.
Old Feb 17, 2006 | 05:17 PM
Country Boy's Avatar
Senior Member
I ran my 1/0 trough the same hole with no problems. I just followed on down the door jam to the back.
For the ground, I sanded a bare spot where the spare is and put it there.
