Fog light?
Old Feb 20, 2006 | 12:03 PM
ninety9ta's Avatar
Default Fog light?
I have a 99 ta that I have just recently changed the fog lights on about a month ago. I installed some sylvania fog lights that I got from advanced auto for 20 bucks each. And after installing them I noticed that one of the lights appeared not nearly as bright as the other. Well today it went out only after a month. My question is, even though they are the same bulbs, why was only on of them bright, and why did it only last a month, and could this be prevented. Any comments would be greatly appreciated. Thanks.
Old Feb 20, 2006 | 06:43 PM
ninety9ta's Avatar
T T T
Old Feb 20, 2006 | 06:59 PM
maddboost's Avatar
Did you touch the bulb with your bare hands? Its generally a rule of thumb to not touch headlight or fog lamp bulbs with your bare fingers. The oils in your skin rub off on the bulb and cause it to unevenly heat and the bulb to pop. Happens alot with the more expensive bulbs because they run so much hotter than regular bulbs.
Old Feb 20, 2006 | 10:10 PM
ninety9ta's Avatar
The bulb was not touched, I made sure of that. Even if it was touched, that would explain why it didn't last long, but it would not explain it being not as bright as the other light. Thanks though.
Old Feb 21, 2006 | 01:35 AM
BuBbABFP's Avatar
probably cause ur fog light housing is dirty.
Old Feb 21, 2006 | 02:01 PM
ninety9ta's Avatar
Yea im gonna open it up and change it out with in the next few days, and I'll clean it out while im at it.
