which wire for pac swix??
Old Feb 23, 2006 | 04:22 PM
mushroom281's Avatar
Default which wire for pac swix??
i think it is the blue wir from the pac but do i just tap into a wire for the radio harness if so which one
Old Feb 23, 2006 | 05:32 PM
steele's Avatar
Pretty sure you use the green wire from the SWI-X and the dark blue wire from the harness. It's been awhile, so I'm not positive. I just followed the instructions that came with it...
Old Feb 23, 2006 | 05:55 PM
5.3litre's Avatar
yes it is the green wire on the pac and on the gray connector there are two dark blue wires, one is surrounded by other wires and one is by its self with no wires right next to it. use the one that has no wires next to it. hope this helps.
Old Feb 23, 2006 | 06:47 PM
sweet thanks guys
Old Feb 24, 2006 | 09:47 AM
ok in my 01 there is no gray plug but a white one with speaker plugs on it with 2 blue wires one on the side with the speakers and another on the other side i tapped into it but the right light will not flash after i let off the volume control
