why arent my subs working right?
Old Feb 24, 2006 | 08:46 PM
Donohue96M6Z28's Avatar
Default why arent my subs working right?
i toko the positive/negative wires off my sub box bc i needed to see how torn up my trunk carpet was from the previos amp i had in there. and when i hooked it back up. my subs are barely working.. one of the wires as writing on it(which i would think would mean positive), but it has a negative symbol on it. i've tried moving the wires around.. and no matter where i put them.. it as the same ****ty sound..nothing better..nothing worse..
could putting the positive wire int he negative slot and vise versa on the sub box.. ruin the subs? any ideas of what im doing wrong? did i ruin anything here.
Old Feb 24, 2006 | 09:24 PM
Matt281's Avatar
switching the polarity wont do anything besides throw the subs 180 degrees out of phase. No, it wont damage the subs. But, they wont sound right.
So youre saying youve wired them both ways, and they still dont sound the same?
Old Feb 24, 2006 | 09:50 PM
ya. im stumped.
Old Feb 24, 2006 | 10:13 PM
Matt281's Avatar
first things id check is the wiring inside the box, unless you know you couldnt have affected it..connections at the amp including the rcas, and the grounding point itself.
Old Feb 24, 2006 | 10:17 PM
ya i was moving the box very lightly, so i wouldnt think that the connectins in the box got loose. but im runningo ut of options.
Old Feb 25, 2006 | 04:54 PM
99blancoSS's Avatar
Here, use this:
http://www.edesignaudio.com/wiring.php or this:
http://www.rockfordfosgate.com/rftech/wiringwizard.asp
Old Mar 1, 2006 | 12:30 PM
Rowdy94's Avatar
yep...check all connections inside your box
