Found the perfect sail panel replacement speakers.
Rev. 00
Delco Electronics
09365799
36908P 0226
Assembled In Mexico
4 Ohm/4 Ohm
02M0626E
So according to these markings, the factory speakers have dual voice coils that are 4 Ohms each, not 2 Ohms each. Is the label incorrect on the speakers?
Rev. 00
Delco Electronics
09365799
36908P 0226
Assembled In Mexico
4 Ohm/4 Ohm
02M0626E
That is corrrect for the Firebird sail speakers. Camaros have 2 ohm single voice coil speakers. The 2 coils are wired seperately to the Monsoon amplifier, so there will be 4 wires to each speaker.
If you decide to drop in aftermarket speakers in your F'bird, you simply hook up one of the coil pairs to each replacement speaker. The two coil channels cannot be bridged, according to other posts on here. Since I don't have access to a Monsoon equipped F'bird (or any F'bird for that matter), I can't investigate why that is so. Note: There's a link in the Monsoon FAQ to a page that gives the wire colors to the Monsoon amp, so you can identify which wire is which.
On a side note, I ended up ordering a pair of factory replacements from txparts.com:
http://www.txparts.com/servlet/the-2...Factory/Detail
They sure sound better than the blown out originals. The store claims that,
