part name?
Old Mar 6, 2006 | 10:20 PM
transambandit's Avatar
Default part name?
whats the name for this piece of hardware they use to wire speakers to a subwoofer thru an enclosure?
Old Mar 6, 2006 | 10:50 PM
Richiec77's Avatar
Speaker Terminal Cup.
Also seen them called: Input Dishes, Speaker Terminals, Speaker Cups, Input Terminals, Input Jacks, a bunch more.
They are not that expensive BTW. Usually only about $2-5 a piece. Sometimes more depending on the quality of the terminal's used and how thick the plastic is. Sometimes they are made of metal.
Old Mar 7, 2006 | 07:34 AM
2MuchRiceMakesMeSick's Avatar
2-5 bucks
Kris your getting ripped
I never used those on any of my cars.
Mainly because you have to cut the speaker wire.
I always drilled a small hole the size of the wire and siliconed the surrounding to keep it air tight. I only used them when the box was going to be removed from the car.
Spring loaded input terminals is what I have always called them
Old Mar 7, 2006 | 06:40 PM
Richiec77's Avatar
That's about what he's going to find them for. I almost never use them anymore.
Hell, the Wall had a total of 2 4ga outputs to a terminal block that split that off into 6 + and 6- speaker wire set's.
