Car subs for home use - possible?
Beyond that, you would need a home audio amp to run the sub. I have an AudioSource Amp Three that I picked up for about $150, that I use for my home subwoofer. It runs at 400W in bridged mode with very low distortion. I've seen 'em on ebay for about that price. I'm sure you can find other amps for less tho, just check ebay. Most any home audio amp will do. Make sure it can run down to 2 ohm stable, and you should be fine. The only trick becomes if your receiver has a subwoofer output - if it does, just plug in the amp, hook up the speaker, and you're done. If it doesn't, you'll need to work out the crossover network as well (or use an amp with a built in crossover).
-Mark
For a small computer level sub, you can get away with a smaller power supply. But for an 8", 10", or 12" subwoofer, you're going to need the power.Here's the types of power supplies I'm talking about.
http://www.etronics.com/listproducts...id=4071&store=
One of these would be used to power a car amp "in the house".
If you watch ebay, you can get lucky. My current benchtop power supply is a PowerOne rack mount unit with 5V, +/-12V, and 24V, and high current... I picked it up on ebay for 6 bucks.
Cost $25 to ship tho.
Price to buy it new would have been about $250. INSANELY loud, but it sucks some juice, all the lights in my townhouse dim when the bass hits
I've got an older JL Audio 15W0 as my home theater sub, in a 3.5 cu.ft. sealed enclosure filled with fiberfill. I power it with a Carver M4.0t amp bridged mono
Nice! Second issue, I absolutely do not recommend you use a power inverter and a car amp to power it. You can purchace an appropriate AC powered sub amp module for the same or less than a high current power inverter. Once you give me info on the drivers I can point you tward an appropriate amp.
Here's a collection of subwoofer plate amps. A lot of them have High Level (speaker level) and Low Level (RCA jack) inputs, so if your reciever doesn't have a dedicated subwoofer output line, you can still use one of these. These plug in to the wall for power, so no external power supply (as discussed above - hey, were were talking about using car amps in the house above!
- now we're talking about house amps in the house):http://www.partsexpress.com/webpage....ctGroup_ID=505
Here's a picture of my homemade enclosure.
http://www.akmcables.com/subwoofer.JPG
It's the first enclosure I ever built, so it's not perfect, but it does look better than the picture leads on.
It's made from 3/4" MDF with a double wall front. I used WinISD (Google for it) to calculate enclosure size and port size based on the specific speaker parameters. The sub is a 12" Dayton Titanic Mk III from Parts Express.The finish is truck bed liner, rolled on the sides and brushed on the front where the sub and port are mounted. The port is 4" flared 18" long (has an elbow inside).
It thumps. I built it more for movies, but it sounds great with music too.
Most home reciever's won't drive 4 ohm loads... and finding a 120 volt AC to 12 volt DC power supply capable of providing the amps needed for a car amp will cost a fortune.
Go with a plate amp. You could even mount it in the sub box and have the box ready for double duty if you ever go back to a car.
Its also a lot easier (cheaper) to get power from a A/C receiver then a DC (12V) convert+12v amp.
Generally a car subwoofer will be deeper then a home audio sub because they are designed to concentrate the pressure more in one area to take advantage of cabin gain. Also its a lot easier, in a car, to get lower frequencies because the wavelengths can be altered to be longer creating a lower (resonant) frequency.
The average car interior (with trunk) is around 12 ft, the 40 Hz note will be longer then the car's interior. This is why notes below 70-90 Hz (depending on the vehicle) will have a greater output than the rest of the frequencies. Once this resonant frequency is achieved the bass output will increase by about 12 dB/octave below that frequency. This is known as 'cabin gain'. A smaller vehicle will have a greater cabin gain and should be able to have greater low bass than a larger vehicle (given were using identical subwoofer systems with identical power).
The cabin gain works well because human ears are less sensitive to low bass. It doesnt matter what type of vehicle you have, the cabin gain will still apply. The firing orientation of the subwoofer system has no effect on the cabin gain but you always want to keep your ports/ducts in the same location.
Bottom line is, you can use car subs in a home enviroment (I do it) but it is not optimal due to speaker design but can be altered (most of the time) by the enclosure and port size/length.
You just need to be careful not to blow up the home audio amp channel in the receiver. Most of the amps will only hold an 8 ohm load. I wouldn't be so much to worry about port, etc. I would be more worried about how power I have to push them and what kind of load the receiver will take. That being said, you need to know the ohm rating on the subs and how to wire it. I agree, I would never use a 12volt conveter to run a car audio amp, it's not worth the trouble. Home audio amps do just fine; I've done it with the neighbor's stuff too. The basic kicker comp's sound great ( I did it with a 12" sub sealed, so does the fosgate punch line (pair of 10s sealed) and cervin vega (2 10s also but I can't remember what model). These all sound great off of about 150watts rms and most home audio players have this for a subout channel. Hell, the new receivers are even better today.
Alot of bandpass boxes will work ok, but will sound peaky as hell and have almost no compensation in above 80-100hz and below 55-40 hz. Makes it sound even worse outside of a car.
BUT, if all you are trying to do is just bump, it may work for you.
BTW Andrew, I need to refresh you on your AMP theory and AB circuits some. (where the hell are you finding 100% efficient AMP's?)
ps. sorry for bringing this back from the dead, but i figure it was better than starting a new thread.
Do you plan to build a new box, or do you have one already?
You shouldn't use a car amp, you will spend more money on a power supply for it than to buy an appropriate home amp. When you tell me what the subs are I can tell you what amp to buy.
