Audio Question, Help...
Old Mar 14, 2006 | 11:05 PM
mrcdvrs's Avatar
Default Audio Question, Help...
I've just replaced my stock door speakers with the Infinity Kappa 62.7. I replaced them because my driver side speaker would distort with any bass levels. I would have to turn the bass **** almost off to lose the distortion. So as mentioned I replaced both front speakers. But the problem still exists not nearly as bad, but I can't crank my sterio. I have the stock monsoon amp and the stock head unit for my 2002 Z28. Any input/ideas would be greatly appreciated.
Old Mar 15, 2006 | 12:11 AM
Rage113's Avatar
Is it still just the drivers side speaker making the distortion? Or do both front speakers sound the same..
Old Mar 15, 2006 | 12:26 AM
Rage113's Avatar
You're gonna need to purchase an aftermarket head unit to make those Kappas sound right anyways. I had the same problem with my front speakers, and replaced them with Boston Acoustics along with a new Eclipse cd head unit. They sound great now.
Old Mar 15, 2006 | 12:31 AM
HiTechGent's Avatar
I like my Monsoon system with my Alpine speakers. But if you like your music loud, or are picky about sound quality, an aftermarket HU would better suit you.
Old Mar 15, 2006 | 01:09 AM
TARZAN's Avatar
Get some bass blockers...
-Will
Old Mar 15, 2006 | 02:06 AM
2MuchRiceMakesMeSick's Avatar
Probably the best route for you would be a 4 channel amp (with a head unit or a high/low level converter) with a built in crossover. Let all 80+hz pass. That will cut out most of your bass which those speakers are not designed for. If you need more then you can look into a stealth box or something similar.
