both cigarette lighters dead??
Old Mar 17, 2006 | 11:34 PM
Hennytime's Avatar
Default both cigarette lighters dead??
i was running a bottle warmer off the lighter to the right side under the cup holder and it went out as i was getting in the staging lanes tonight. now neither work, is there an easy or quick fix for this?
Old Mar 17, 2006 | 11:39 PM
BeemerZ28's Avatar
its a fuse
Check the fuse box on the drivers side same **** happened to me randomly
Old Mar 17, 2006 | 11:44 PM
Hennytime's Avatar
would it matter changing the amp rating of the fuse?
Old Mar 18, 2006 | 07:30 PM
'99slobird's Avatar
You can put the same size in it, or go one higher if you have to. General rule of thumb they told me in college, if you have to fuse up, go up as close to 10% of the original rating as possible. Of course if you have a 15 amp fuse to start with, you can't get a 16.5 amp, but I think that you get what I mean.
Old Mar 18, 2006 | 08:06 PM
TARZAN's Avatar
If the stock fuse has been working fine till then, then put one back in it....just my .02
-Will
