Will this work.(GM9-AUX)
Old Mar 20, 2006 | 12:57 AM
Ryan1985's Avatar
Default Will this work.(GM9-AUX)
My car is a 02 camaro with a monson system but no cd changer.
http://cgi.ebay.com/NIB-DPX-Technolo...QQcmdZViewItem
I just want to make sure before i buy.
Thanks
Old Mar 20, 2006 | 11:30 PM
Ryan1985's Avatar
i know someone has to know.
Old Mar 21, 2006 | 07:38 AM
WhiteBird00's Avatar
Ungrounded Moderator
Yes, it's the right one for your car.
Old Mar 21, 2006 | 08:50 AM
Michael55123's Avatar
It will only work if you have a cd changer. I have the unit myself. If the cd changed isn't on, and playing, it doesn't work, and you'll get no sound. I'm 100% sure of this.
Old Mar 21, 2006 | 08:51 AM
I lied thought that was a standard PAC gm9-aux, no clue about the one you posted. The PAC works inline with the cd changer, and allows you to keep it, not sure if that one is the same. PAC also has 2 aux ins.
Old Mar 21, 2006 | 09:02 AM
To clear up the confusion - there are two different companies that make these kinds of adapters, Pacific Accessories Corp (PAC) and Peripheral Interface Electronics (PIE). PAC adapters (AAI-GM9) require the factory CD changer be installed and functioning for the auxiliary input to work. PIE adapters (GM9-AUX) don't have this requirement. In fact, on models prior to 2001 you have to disconnect the factory changer to use the GM9-AUX. 01 and 02 models have the ability to connect two external devices so you can have both the factory changer and an auxiliary input connected at the same time if you want.
Old Mar 21, 2006 | 02:55 PM
Ryan1985's Avatar
Thanks alot guys.
