power wire
Old Mar 24, 2006 | 03:50 PM
MxWickedZ28's Avatar
Default power wire
i was just wondering if i had to put hte power cable to the actual positive post ont he battery or could i put it near the fuse blocks where it has the (+) in red. would it basically be the same??
Old Mar 24, 2006 | 04:38 PM
HiTechGent's Avatar
It depends on how much current your going to be drawing. If your installing a high powered sound system drawing lots of juice, you had better not only attach it to the battery post, but also ought to beef up the ground cable, and the cable that goes between the alternator and battery.
Old Mar 24, 2006 | 05:28 PM
im only running 2 mtx thunder 6000, with a borrowed sony xplod amp i think about 720w peak would i be safe at the fuse connection
Old Mar 24, 2006 | 10:48 PM
daryl2cb@yahoo.com's Avatar
yes that should be fine
