Anyone relocate their battery?
Old Mar 31, 2006 | 02:53 PM
davewbremer's Avatar
Default Anyone relocate their battery?
Hey guys, in trying to relocate my battery to the rear passenger side wheel well on my 2002 T/A, everything was going fine till i had to find a hole in the firewall to run the 0gauge red lead through; the tight rubber boot for the PCM feed is too tight to accomodate; i know alot of you have gone through this execise before; I have a coil of 0 gauge sitting under the front pasenger carpet hoping for some advice. Did anyone drill through pan or tunnel area to get inside engine bay? Is there a hole that I am missing? Wow is it congested! - Pics are definitely welcome - thanks in advance
Old Mar 31, 2006 | 05:48 PM
jimmy 2 Times's Avatar
did you take the pcm out? one you remove it, you will see the factory grommet
By Brett Foote | 2026-06-04 05:00:17
