Factory Alarm Question
Second, you can get the DEI Hornet 727T Keyless Entry Upgrade system. It is an aftermarket alarm system that is designed to integrate with your factory keyless entry and use the original factory remotes. You can find it online for about $75 and the whole thing (except the siren) can be wired right at the BCM so it's relatively easy to install. I have had the older 700T model in my car for three years now and it has worked flawlessly. I also added the perimeter sensor to protect the car when the t-tops are off.
