monsoon head unit and system
Old Apr 16, 2006 | 11:54 AM
captaincamaro's Avatar
Default monsoon head unit and system
can i put a system using the monsoon head unit? i want to buy this package that comes with 2 12s, amp, and all the wiring.
http://www.woofersetc.com/index.cfm?...roduct_ID=3023
theres the sub and amp(i know im cheap)
thanks
Old Apr 16, 2006 | 06:21 PM
TA4life's Avatar
yes, you will need a high level to low level converter. you look it up to your sail pannel subs and it sends the signal to the device and converts it to low level(rca hook ups) worked flawless for the month i used mine before i bought a headunit. i have one forsale that i used for a month if you interested. pm me
Old Apr 17, 2006 | 08:27 AM
todddchi's Avatar
Check to see if that amp has high-level inputs before you go buying a line-level converter. It may or may not be required.
I would also recommend that you tap the rear outputs of the radio itself, at the input connector of the monsoon amp, to grab your signal, whether you use a line level converter or not.
The monsoon radio just sends four normal high level signals to the monsoon amp, which you can grab at the amp input connector.
Grabbing your output here instead of at the speaker connections eliminates another level of distortion from the amp stage.
