Monsoon stereo help.
Old Apr 17, 2006 | 10:27 PM
DALLAS's Avatar
Default Monsoon stereo help.
Does anybody know factory Monsoon stereos well? I just replaced all of the factory speakers except for the driver side back seat speaker. Would that cause the system to not operate at full strength? I'm pretty sure it should be able to go louder than what it does. It makes a popping sound when it is turned up too far.
Old Apr 18, 2006 | 08:57 AM
HiTechGent's Avatar
Depends. What did you replace the speakers with? Did you just replace them with other factory Monsoon speakers? Or with aftermarket?
Old Apr 19, 2006 | 02:05 PM
DALLAS's Avatar
I installed factory monsoon speakers.
Old Apr 19, 2006 | 03:57 PM
ded71's Avatar
If you installed factory speakers correctly I don't see how that could be the problem. Were you having any problems before you replaced the speakers? (other than the obvious).
Old Apr 19, 2006 | 04:00 PM
DALLAS's Avatar
The car had an aftermarket stereo system in it when I bought it. I traded it off for performance parts. So I just wanted to put a factory monsoon system back in it. If it did have problems before I wouldnt know. I was kinda wondering that myself. Maybe the guy that had it before me had problems with it and decided to put all aftermarket stuff in.
Old Apr 19, 2006 | 04:20 PM
ded71's Avatar
Does the car still have all the factory plugs and harnesses? Some people butcher them up pretty bad when they go aftermarket. The monsoon is sorta complicated, if you have to wire everything up the hard way that is.
Old Apr 19, 2006 | 04:53 PM
DALLAS's Avatar
I have all of the speakers connected through the harnesses.
