sail panel speaker question
Old May 4, 2006 | 12:09 AM
peterlawl84's Avatar
Default sail panel speaker question
im getting a second amp to run 6 1/2s in the doors and 5x7 in the hatch area. i am also removing the stock amp, i was wondering if it would be ok to hook up the speakers in the sail panels to the new amp or if i should just remove those speakers also.
i do not know much about stereo stuff, so sorry if this is a stupid question.
thanks in advance.
Old May 5, 2006 | 09:20 PM
ded71's Avatar
Which car do you have? the sail panel speakers are different in camaros and firebirds. One is a DVC one is not.
Old May 6, 2006 | 02:20 AM
sorry, i have a 99 t/a. it came with the 500 watt monsoon system, i have replaced the headunit with an eclipse unit as well as the door speakers and hatch speakers.
Old May 6, 2006 | 08:05 AM
SOMSS's Avatar
Just disconnect the sail pannel speakers, they are useless as subs. They are too close to the front to act as fill speakers. I replaced my system reciently and used 6.5" components in the rear hatch for fill and MB Quart's in the front.
Old May 6, 2006 | 01:15 PM
so they are only low range speakers in the sail panel? if thats the case, then i'll just remove them because i have 2 10 in subs. the door speakers are 6 1/2 components. i just wasnt sure if it would sound better if i left the sail panel speakers in or not.
Old May 9, 2006 | 03:22 PM
ded71's Avatar
If you have two 10's then I would forget all about the sail panel speakers. I added one ten, and then replaced the sails with coaxs. I like rear fill.
Old May 9, 2006 | 11:25 PM
sgt0704's Avatar
i'd say get some mids or something, then wire them to the amp.
