Speaker Grills Suggestions
Old May 16, 2006 | 04:17 PM
redarrow's Avatar
Default Speaker Grills Suggestions
I thought I had cracked speakers because they would rattle. Well today I reached back and held the grill and the rattling stopped. Is there any classy way to tighten up the grills so they don't rattle when the volume is turned up???? It is the ten speaker monsoon system btw.
Old May 16, 2006 | 04:22 PM
you2slo's Avatar
Find a way to use double sided foam tape?
Old May 16, 2006 | 04:51 PM
2001NBMZ28's Avatar
The grille on my drivers side door does the same thing - reach down and put pressure on it and it stops. Going to put foam tape on mine one day when the window motor goes and have the panel off. The rears are easier to insulate.
Old May 16, 2006 | 05:40 PM
sgt0704's Avatar
the door panel takes bout two minutes to pull off. stop being lazy and do it now.
