bad tach?or bad connection?
Old May 23, 2006 | 05:18 PM
darbydarby's Avatar
Default bad tach?or bad connection?
installed a 5" tach today on my 98 camaro.tapped the signal wire into the #35 white wire on the top of the pcm like everyone said to.
the tach shows an rpm,but its hella laggy and not accurate at all.
could a bad connection cause this?we tried re-doing it but it didnt seem to help.
also if its a cheap tach could that be the problem?its not a name brand tach at all.
help
Old May 23, 2006 | 11:07 PM
darbydarby's Avatar
Old May 23, 2006 | 11:10 PM
2MuchRiceMakesMeSick's Avatar
Its hard to say as it could be either.
If you have already rewired it I would lean towards a bad tach.
You might try soldering the connection and see if that helps.
Old May 24, 2006 | 08:27 AM
WhiteBird00's Avatar
Ungrounded Moderator
Did you set the tach for a 4-cylinder configuration? The LS1 PCM outputs two pulses per revolution so you have to set the tach to 4-cylinder rather than 8-cylinder to get a proper reading.
Old May 24, 2006 | 11:46 AM
darbydarby's Avatar
ok so set it at 4 cyl?
Old May 24, 2006 | 12:20 PM
Yes, that should take care of the problem.
