problem with air/fuel
Old May 23, 2006 | 10:22 PM
flash12t's Avatar
Default problem with air/fuel
i installed a autometer air/fuel gauge . . did the wiring but it reads so slow. .and it doesnt bounce back and forth it just stays in one light . . can anyone help my thought is that o2 sensor might be bad it rattles like crazy now. .
Old May 23, 2006 | 11:23 PM
2MuchRiceMakesMeSick's Avatar
Which autometer A/F ratio gauge did you get?
Do you have a wideband?
Which wires did you hook up where?
Old May 24, 2006 | 01:45 AM
imnotplutonium's Avatar
yea need more info. make sure your signal wire is the purple one from the o2. if it is stuck on one led you could have 1 of 2 problems i had. either your not spliced into the right signal wire, or your o2 is bad. your car will run like crap if it is so you should know. I used one of the blue slicers to do mine and i didnt push the metal blade far enough in and it never made a connection. that was my problem for the longest time.
Old May 24, 2006 | 12:24 PM
flash12t's Avatar
sorry bout that its a cobalt air/fuel .. i have it all hooked up the #65 pin. and have the rest of the wires spliced in to my valentine radar . it works just has a bad delay like when i go wot it go to rich and when i let go it turns off or goes to rich. . and when im just crusing it just stays on the last light it sees. .
Old May 24, 2006 | 11:11 PM
flash12t's Avatar
anyone please this thing is bugging me tomorrow is my day off. . please. .
