Questions about the monsoon system
1. how is the monsoon system compared to non monsoon system and is it any good?
2. where is the amp located for the monsoon system?
If you have a car with the base 4 speaker stereo then doing a standard deck/4 speaker upgrade will get you above monsoon quality levels easily. The best bang for the buck would be to upgrade door speakers (treble and midrange) and add a small subwoofer (maybe a tube).
If you have an existing system in your old car then the transistion is not as painful as you might think.
- The head unit drops right in, old fashioned GM harness install, no trickery.
- PAX makes a steering wheel control unit, about $40, that turns the steering wheel inputs into a remote signal. So long as your head unit has a wireless remote, for $40 you can keep the wheel controls functional, and actually program any button function you want.
- 6.5" door speakers drop right in, and if you mod them to be bi-wired, you retain the factory amp power, which is actually fairly decent (about 20-30 rms per channel).
Transferring the head unit and front door speakers will be a major upgrade, if they are decent equipment.
If you want bass then a sub is the only way to go. Trying to add bass to a monsoon system via driver replacement just doesn't work very well.
