Cd Changer for monsoon.
Old Jun 8, 2006 | 08:28 PM
pHEnomIC's Avatar
Default Cd Changer for monsoon.
I took the 12disk delco cd changer out of my camaro and put it in my t/a (the camaro has an aftermarket hu and can't use it.)
It seemed to power up fine and all, the head unit recognizes it and such but I get errors. Anything special i have to do to make it work? I hear it is compatible (i realized i only used burned cds for testing, will have to try a non-cdr when i get a chance.)
Any other ideas?
Old Jun 8, 2006 | 09:36 PM
HiTechGent's Avatar
You've figured it out. While the Monsoon head unit will play some CD-R's (I've read it doesn't seem to like CD-RW's), the CD changer will typically only play bought CD's.
Old Jun 8, 2006 | 10:11 PM
pHEnomIC's Avatar
I tried two cds that I bought no luck. I get the Error 30 on my head unit.
Old Jun 9, 2006 | 10:24 PM
HiTechGent's Avatar
OK. This is probably a silly question, but did you remember to put the CD's in the cartridge label side down?
You might try pulling the unit out, carefully removing the cover and try spraying to out with a can of compressed air or electronics spray to clean out any dirt or debris that may be gumming up the works.
Old Jun 10, 2006 | 01:48 AM
pHEnomIC's Avatar
Bingo!, That was the problem. I had never used the changer and it just came with my camaro (was uncompatible), This is awesome. I love this thing, a lot better than changing cds when i want different songs and it does in fact read cd-rs. Thanks!
