Alt, wiring problems
Old Jun 18, 2006 | 10:15 AM
BADRAT's Avatar
Default Alt, wiring problems
I am putting a 02 LS1 /4l60e in a 36 chev,, we used the S&P harness and reprogramed comp,, On wireing up the alt,, I took the alt connecter and wire out of the origional loom and found it has a 1 wire in a 4 wire connecter, my question is how do i wire this into my charging system, using the origional, ls1 alt, thanks
Old Jun 18, 2006 | 10:37 AM
227Hawk's Avatar
The single wire is the excitor wire. I'm pretty sure that goes to keyed 12v.
Hawk
Old Jun 18, 2006 | 11:11 AM
BADRAT's Avatar
thanks hawk,, this single wire won't charge the system will it,, this is the only wire that was ever on the origional harness or alt,, [only 1 wire on the 4 pole connector] if this is the exciter wire,, it should have another wire to carry the charge to the system shouldn't it? there was never more than 1 wire [small wire at that]
Old Jun 18, 2006 | 07:28 PM
HiTechGent's Avatar
It should have a (+) terminal wire that bolts onto the alternator. THe (-) terminal is the alternator housing and is ground to the chassis thru the mounting bracket.
Old Jun 19, 2006 | 08:20 AM
227Hawk's Avatar
There will be a discharge outlet stud on the back of the alternator. This ties into your battery the same as any other charging system.
Hawk
